(ej1) where should i run reverse light wires from center cons to trans?
more specifically, where is an easy, (not hard to get to lol) place in the firewall where i can run the wire? I did an auto to manual swap and i'm pretty sure people have had this dilemna. thanks all
Re: (ej1) where should i run reverse light wires from center cons to trans?
srry to reply so late, can anyone lead me to a layout of the firewall? i know theres lots of holes but i dont want to go removing most of the dash to get to it, what were you guy's solutions to getting wires from the cabin to the bay?
Well have you even looked under your hood, theres like at least ten holes with rubber grommets you can run them through and have it easy to run it to the plug. Not being a dick, just saying, looking won't hurt you.... If your still curious ask or look around how to run the power cable through the firewall for an amp, that will answer your question.
i know i have to run wires to the battery to the amp when doing a sound setup, i've looked and confirmed all the holes in the firewall, what i'm getting at is that are there any simple holes that are accesible WITHOUT removing large portions of my dash
thats the #1 situationthat i'm asking.
i've look under the dashboard, pulled back some carpeting and didnt see holes, thats as far as i got before i took any part of the dash off
You need to remove the grommet and you will see a black sound deadner thing, peel it back and you will see it.
On the passenger side near your battery, there is a grommet, remove it, stick a flash light or have a friend stick a wire or flash light directly into it, go under the dash on the passenger side, pull the carpet down and you will see the hole there run the wires through, and run them through, remove the cup holder section and other parts that you need to remove to get it off, run the wires along the fire wall under the carpet to the center and connect wires.
lmk how that goes, im under-going that procedure tomorrow
