swaping d to b
swaping d to b
got a 99civic ex< the car is obd2b getting a jdm b18c obd2, what all do i need to do the swap besides the swap itself, i know i need 99-00 rear bracket, and sidepost mount on ds by the timing belt, my main question is will the dseries ex wiring harness run the b18c? or will i have to do a **** load of wiring?? thanks in advance, also i did search and i only found obd 1 stuff
Re: swaping d to b
i think the only thing you really need to do is run some wires for the iabs (secondary butterflies). this is assuming you are getting the jdm gsr, not the type r.
Re: swaping d to b
yes its a jdm gsr< done some home work and have to swap the dizzys wires from the 8 point plug to a 10, anyone know any other wiring?
Re: swaping d to b
rywire.com they make all the harnesses u will need not a fan of odb2 just hope the motor had odb2b harness on it if not then do odb2a to odb2b harness swap (comes with everything even all the jumpers)
Re: swaping d to b
u need the axles, i-shaft, mounts, b20 or b16 delsol ac bracket, b series tranny bracket, , i used my 99 civic ex harness on my b2o w/gsr head, works fine, some short wires, but runs fine
Re: swaping d to b
there is a big metal bracket on the front that goes to the torque mount and a mount on top of the trans, can i use my dseries ones?
onesiksupra
12-01-2006 11:56 AM
