Running cold, strange temp needle
b7/z6 mini me eg cx..
coolant topped off, oil level good.
I drove 45 freeway miles this morning and the temp needle was stuck below the C. As soon as i stop in traffic and idle for a minute, it starts to raise up to 1/4. I take off again, i have some white smoke and the temp needle drops below C again. The problem repeats everytime i idle for more than a couple minutes.
Idle is around 500-1000 pulsating/fluctuating/bouncing, whatever you want to call it. Havent checked the thermo yet, i've been reading that could be the culprit.
Re: Running cold, strange temp needle
what about the white smoke tho? it only blows out in short bursts just AFTER idling. like i said i drove 45 miles mostly at around 70mph and i had no smoke until i hit a bit of traffic.
Oh, side note, since i have a cx cluster, how can i go about using an SI cluster and hooking up my tach? Does the cx tranny have a spot for a VSS? I have an aftermarket tach that is hooked up and working.
it is plug and play, even though there is no tach on a cx, all the wiring is there and the si cluster will be fully function.
4g you get a new car? and i agree with everything above, thermostat and plug and play, i just put a ex cluster into my dx sedan works great
But yea, i'll take care of the thermo this coming weekend and i hope i can find a SI cluster.
beaterman
02-20-2012 05:49 PM
YellowR2000x2
05-22-2005 02:04 AM
