i need help please
i need help please
Im doin a swap in my car from a 93 1.5 non vtec engine to a 99 1.6 vtec engine. I dont have a Ecu with the new motor and i dont know which one it uses, and is it obd1 or 2 or do i have to do some type of conversion or what. i really need help with this b/c i'm stumped on what i have to buy
Re: i need help please (DriveSideWays)
a 99 motor will be OBDII. There are harnessess so that you can use an OBDI ECU with an OBDII system. Also I don't think your car is wired for VTEC, so you'd need to get a wiring harness also.
I really don't know much about swaps though, this is more of just a bump.
Re: (DriveSideWays)
Stay OBD I.
You need p28 ECU.
Injectors from your old motor.
Distributor from your old motor.
And wiring harness from old motor.(ODB I harness)
Install all this on the EX motor and switch any sensors that wont plug into your ODB I harness to the ones from your old motor...
Then you just gotta add some wires for VTEC and everything should run fine...
You need p28 ECU.
Re: (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">Stay OBD I.
Hmm I thought Non Vtec Distributors are different then vtec ones.. so if that was the case using his older one will not work.
Global Moderator
Re: (EVIL Hx Coupe)
You need p28 ECU.
I second that
You need p28 ECU.
I second that
