Can someone please answer my fuel pump question
i am alost done with my b20. its goin to be turbo my next month. i just wanted to kno if a stock eclipse gst fuel pump will work with my setup and will it be more than enough. If not what other stock pump can i use?
Re: Can someone please answer my fuel pump question (jp300zxtt)
if you going boost then get you an aftermarket fuel pump 255lph. "walbro" fuel pump or something..
Re: Can someone please answer my fuel pump question (2lua)
why go through the trouble of seeing if a different manuf./make will fit in your car, and it might not even be enough for your needs? What kind of turbo setup, what kind of hp goals? man, just fork out $109 bucks... go to
http://www.lightningmotorsports.com/walbro.htm
part # GSS317 (400-846)
comes w/ everything you need to bolt it in, and forget about it...
Re: Can someone please answer my fuel pump question (TRUST8383)
i kno i can go after market i just wanted to kno if there was another way to go. i just put a walbro in my friends eclipse gst, and he gave me his old pump. i just wanted to kno if i was able to use it.
viet_boi_racin
02-03-2008 09:34 AM
