aftermarket timing belt?
Old 11-12-2003, 09:59 AM
duncan's Avatar
Default aftermarket timing belt?
I have to replace this a little early, mainly because my water pump is leaking. My mechanic wants to put a Gates belt in while I'd rather have a Honda. Is there a big difference? I'm wondering who actually makes the belts for Honda in the first place.
Also should I get a new Honda water pump? I think the last one was a rebuilt but I'm not sure, but it developed a slow leak after about 55k miles and now at about 80k it's a fast leak and I can't go much farther on it, as topping the antifreeze every day is getting old. Thx.
Old 11-12-2003, 10:10 AM
bogus_ek's Avatar
Default Re: aftermarket timing belt? (duncan)
don't know who makes oem honda belts, but i'm sure that it wouldn't make that much of a problem esp if your mechanic is recommending it... ask him if there is a warranty on the timing belt. i think honda belts are only supposed to be replace like every 100,000 miles. as far a water pump goes... brand new from honda will run you quite a bit. check out "inlinefour.com" they have good prices on oem belt, pump etc... i just got mine from there.
Old 11-12-2003, 10:12 AM
SOHC_MShue's Avatar
i wouldn't use any timing belt other than oem. Just not worth risking your motor.
Old 11-12-2003, 10:13 AM
btleier's Avatar
Default Re: aftermarket timing belt? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't use any timing belt other than oem. Just not worth risking your motor.</TD></TR></TABLE>
Old 11-12-2003, 10:59 AM
CRITTERMATT's Avatar
The OEM Honda Belts are made by Gates. I just put one on two weeks ago and it has the Gates Logo on it. I have bben told that they are chaeper through Honda than NAPA. I have not confirmed this though. Check http://www.Hondaautomotiveparts.com they are only like $18.00.
This is for a D16Y8 and also the waterpump is like $45.00. Mine was leaking and I didn't know it.
Thank god I had ordered one since people on here recommended I replace it
Old 11-12-2003, 11:01 AM
Old 11-12-2003, 11:15 AM
btleier's Avatar
Default Re: aftermarket timing belt? (CRITTERMATT)
rendezvous
tony_2018
07-20-2014 02:59 PM
globy123
18
08-02-2008 09:53 AM
beeroh
11-23-2004 08:42 PM
Neeko
05-04-2002 12:41 AM
Quick Reply: aftermarket timing belt?
