15's and wilwood kit or 16's and big brake kit?
jus f0 dekarayshunZ
Re: 15's and wilwood kit or 16's and big brake kit? (electric_)
id say get the 15's and run the wilwoods...on vtecvoodoo he might be able to shed some light on this i believe he was running them on his "ek"
they DO NOT fit under slips unless u run like a 10mm (if not more) spacer. the wilwoods are aluminum and will flex outward under heavy braking. i was running slips on my race car with 6mm spacers, and they were rubbing. however, speedmasters w/ a 6mm spacer will fit.
not sure about SW388's
some 15's will work and some will not
Re: 15's and wilwood kit or 16's and big brake kit? (Hunter)
i kno this comment seems pretty riced out, but will the AEM big rotor kit fit under 15" rota circut 8s .... this is for a 95 EJ .... or will they clear the slipstreams??
i even considered shaving a lil bit off the mounting bracket to eliminate as much of that brake pad overhang as possible ... i even considered running a fatter spacer (15mm up) to get the AEM kit to fit ... o well i guess i gotta fab it and see what works
CoreyR
11-28-2005 05:48 PM
masshatch
12
12-04-2004 07:03 AM
KiDSoL
12-01-2003 02:59 PM
