Question about Flow of a Test Pipe
Recently gutted my cat and it sound like *** now (which i expected just did it b/c it was clogged) and it popples and crackles and its super loud with my apexi n1 catback and dc sports 4-1 header and i was wandering if i just get a test pipe if it will quiting it down or take the popples and crackles out or will it sound the same.
Will i haft to by another stock Cat..if so anyone got one for cheap?
Edit : sorry for the spelling
Re: Question about Flow of a Test Pipe (USDMDC2)
A normal smooth pipe that is the same diameter as the rest of the exhaust will have flow like there was never a catalytic there.
Punching out the catalytic material is a bad idea, because the OEM cat opens to a wider diameter because of the restriction of the catalytic material, remove that and it can impede the flow and pulses.
Re: Question about Flow of a Test Pipe (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">A normal smooth pipe that is the same diameter as the rest of the exhaust will have flow like there was never a catalytic there.
Punching out the catalytic material is a bad idea, because the OEM cat opens to a wider diameter because of the restriction of the catalytic material, remove that and it can impede the flow and pulses.</TD></TR></TABLE>
that was exactly what i was trying to tell everyone else on another post/thread when the dude wanted to gut his cat out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 »</TD></TR><TR><TD CLASS="quote">bump...so ovasly i know to go with a test pipe....is there a way to make your own test pipe?? and weld some flanges onto it?
yeah, buy piping, weld flanges.
s
s
had a test pipe and i felt no difference in sound or anything even when i put my old cat back on there was no difference.
Re: Question about Flow of a Test Pipe (KiDSoL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KiDSoL »</TD></TR><TR><TD CLASS="quote"> had a test pipe and i felt no difference in sound or anything even when i put my old cat back on there was no difference.</TD></TR></TABLE>
So what are you saying by this?
I need to get rid of this un godly nasty *** sound..it sound like i have an arospeed exhaust.. Does gutted cats cause that nasty buzzing??
Re: Question about Flow of a Test Pipe (KURRRWA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRWA »</TD></TR><TR><TD CLASS="quote">trust me I have done the same thing
Test pipe is way quieter
Racingpipes.com $35 shipped w/o bung, $40 shippd with bung
good info! thanks
good info! thanks
no it wasnt aerospeed, where i bought it doesnt sell aerospeed and no there was no difference whatsoever in noise at all, not buzzing, not louder not softer. My firned gutted his and it was nasty sounding, I'd go with what they said to buy. for 35 bucks you can't go wrong. I have stock exuaust so maybe thats why. (Del Sol SI)
i had one on my hatch, top end was alot better. Got noticable louder. I also just did the gutted cat thing on my ef. Flows much better then having it not gutted. But like people say. It does create turbulance, which is a bad thing when it comes to flow velocity. Test pipe would be better then gutted cat. So it depends how cheap you are.
Suggestion: get a testpipe, keep the cat ungutted. Its worth alot more that way if you decide to sell it!
Re: Question about Flow of a Test Pipe (screamincivik)
Ok guys..back from the dead
I went to pep boys bought a 2.5 pipe and my friend (shadyed9's) friend aaron..cut the flanges off of my stock cat and re welded them onto the pipe...turns out it bolted right up and the sound is SO much better..thanks guys
i am glad everything worked out for you
i am thinking about getting on one my car with just a n1 axel back
was it louder, does it smell?
Re: Question about Flow of a Test Pipe (ek9mugen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9mugen »</TD></TR><TR><TD CLASS="quote">was it louder, does it smell?</TD></TR></TABLE>
Louder than w/the stock cat yes, and yes it does smell like ****.
Re: (stock93cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx »</TD></TR><TR><TD CLASS="quote">sorry to steal your thread, but with all this hype about straight pipes, will it make yiour engine run leaner?</TD></TR></TABLE>
No and make your own thread next time
hatchit_B16
06-25-2008 07:11 AM
BigMoneyP
04-26-2005 07:02 PM
