help with bracket, just did swap
hey i jsut did a b18c1 on a my friends eg and the front brackets wont fit (eg), the brackets im refering to is number 1, 2, 12, 14, 15, and 10. what brackets will fit?
Re: help with bracket, just did swap (stock93cx)
get the correct Bseries A/C bracket and it should line up with the vibration mount on that side. Same goes for the Tranny side.... I could be wrong though.
Re: help with bracket, just did swap (EG2 SiR)
i beleive your right.
the two torque mounts(both front mounts)
the bseries version should work just fine
Re: (iamsam7400)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamsam7400 »</TD></TR><TR><TD CLASS="quote">what bracket did you use? from d15 motor or b-series?</TD></TR></TABLE>
o sorry for not clarifying it, he used the brakets from his d15 and it didnt line up. so any b series will work?
Modified by stock93cx at 11:07 PM 11/12/2003
I might be a little confused. Let me get this straight. You are talking about the bracket with the bushings, right? If so this is what you do. Grab the GSR mounts(AC and tranny) and take of the GSR brackets that bolt up to the frame of the car. Next, install your stock civic brackets onto the GSR mounts. Now they will work. The difference is that one has an indentation and the other does not. That's why it does not work. Good luck. I hope this is what your talking about.
Re: help with bracket, just did swap (TurboCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCX »</TD></TR><TR><TD CLASS="quote">I might be a little confused. Let me get this straight. You are talking about the bracket with the bushings, right? If so this is what you do. Grab the GSR mounts(AC and tranny) and take of the GSR brackets that bolt up to the frame of the car. Next, install your stock civic brackets onto the GSR mounts. Now they will work. The difference is that one has an indentation and the other does not. That's why it does not work. Good luck. I hope this is what your talking about. </TD></TR></TABLE>
huh?
huh?
integra321
07-24-2007 12:36 PM
Nicaraguense13
09-01-2006 08:54 AM
thrty8street
04-08-2006 12:21 PM
