Changing oil question
When you are refilling the oil if you go over the needed amount do you have to empty out all the oil and try again until you get it perfect? What are the consequences of having too much oil?
Re: Changing oil question (Knocturnal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knocturnal »</TD></TR><TR><TD CLASS="quote">When you are refilling the oil if you go over the needed amount do you have to empty out all the oil and try again until you get it perfect? </TD></TR></TABLE>
LOL! No man just drain a little out.
Re: Changing oil question (Mr Milano)
i heard that TOO much oil will make your car run like ***,...if you have more than whats needed in,..just take the drain bolt off for a couple seconds and then put it back on,..no big deal
loosen your drain plug and let it drip out or if you can get under your car easily as in standing under it you can tilt the plug right when it is about to come out and hold it till a little comes out , then check it. May take a few times depending on how much over it is. you dont have to start it up each time to check the level. Once you have changed the oil and started it and after you have oil pressure and no leaks shut it off. oil will stay in the filter and you can get an accurate reading
loosen that plug up and let a little out you def dont have to drain the whole thing pull the plug count to like 1 or 2 and put it back in you should be good..
OG triple OG
Re: Changing oil question (Marauder)
3.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">How much did you put in?</TD></TR></TABLE>
Re: Changing oil question (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">3.5
That's how much your supposed to use.....I'm wondering how much the guy put in who started this.
OG triple OG
That's how much your supposed to use.....I'm wondering how much the guy put in who started this. </TD></TR></TABLE>
but i put in 3.5 and my oil is quite a bit above the top dot
but i put in 3.5 and my oil is quite a bit above the top dot</TD></TR></TABLE>
seriously?? Was your engine cold when you let it drain? Sure you let it drain long enough?
EGgoJDM
12-01-2009 12:05 PM
todaspecsi
46
04-29-2004 05:08 PM
