d series pistion? compression to octane usage question?
What are the best pistons to use for a n/a d16z6 motor to get the right compression for 91 octane. Im pumping 91 octane..and will be running on a stage 2 zex cam with i/h/e.
Re: d series pistion? compression to octane usage question? (trooper0641)
do a search, you have spade's D series post with tons of piston info which I and others have contributed to. it all depends on how much compression you are looking to get, that will determine which piston to choose. most likely youll want the p29/a1,zc, or something like a d16a6 piston. stay away from d15 non vtec pistons regardless of what people say, unless you like pistons sticking out of the bore.
Re: d series pistion? compression to octane usage question? (JaeOne3345)
what kind of compression am i looking @ with the d16a6 piston? Does it work well with 91 octane on the z6?
use the search button.. and this calculator http://www.knology.net/~jediklc/
I would think you would be fine with the a6 pistons and 91 octane. With the a1 pistons you would definantely need 93 though.
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 »</TD></TR><TR><TD CLASS="quote">stay away from d15 non vtec pistons regardless of what people say, unless you like pistons sticking out of the bore.</TD></TR></TABLE>
Yeah...I think I was the one who posted that and people listened to me...whoops
For 91 octane i'd recommend A6 pistons
Re: d series pistion? compression to octane usage question? (BauleyCivic)
Is 10.744 a good compression for 91 octane?
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">Is 10.744 a good compression for 91 octane?</TD></TR></TABLE>
sure, just get some type of management for it. Your stock ecu is sendng out maps for a 9.2:1 setup...so you'll need to be tuned in a bit.
But it will be fine on 91
