Power Locks Not Working, Windows, sunroof 1996 civic ex coupe
Old 08-28-2015, 07:56 PM
lustworld's Avatar
Default Power Locks Not Working, Windows, sunroof 1996 civic ex coupe
Fuses are good and intact..... the problem i have is that the previous owner rigged all the wiring to the locks harness... the door on passenger ONLY unlocks when you press up on the side mirror switch and before you do so.. you have to switch it to R(right) but it doesnt unlock both doors all... ive tried using the lock switch obviously... also my side mirrors wont work, only the right one does but it can only be adjusted side to side...
Also.. the harness that connects to my door (coming from fender) which
operates windows, locks, speakers.. etc. has worn out to my 96 civic ex.. so
I went to the junkyard and got an hx harness (I clipped it from where it
comes out through the fender and into the door) and put it on my ex... after
I did so MY SUNROOF stopped working... could it be because of fault
harness??
My speakers work well both sides and back,
But my sunroof, windows stopped. Completely??
Old 08-28-2015, 08:21 PM
lustworld's Avatar
Default Re: Power Locks Not Working, Windows, sunroof 1996 civic ex coupe
Anyone help? ?????
Old 08-28-2015, 08:52 PM
Former User's Avatar
Replace obviously hacked wires, and check for broken wires in the door jamb connectors.
Old 08-28-2015, 09:56 PM
Stancetard Hate Monger
eghatch9295's Avatar
hx- no sunroof. duh.
Old 08-29-2015, 04:01 AM
chrysler kid's Avatar
Abandon the factory connector and replace the wires.
My advice is to pull one side back through the door and the other side back into the cabin yo give you clear access to the wires. Extend the ones from the door using new wires and feed the new wires into the cabin. Be sure to wrap everything up nice and tight.
FYI my hx just had crimp connections where the plug use to be and it had problems. I had to re do them all as I described above
I'm not aware of any sunroof wiring going through the door but I have an hx no sunroof
Old 08-29-2015, 08:00 PM
lustworld's Avatar
How do i know which wire goes where to the door jamb harness?? I tried looking for those at junkyards but no luck... i dont understand why it wouldn't work in the forst place if theyre both power doors and windows... difficul finding that harness
Old 08-29-2015, 08:01 PM
lustworld's Avatar
Is there some sort of diagram i can look in to??
Old 09-02-2015, 09:51 PM
lustworld's Avatar
Problem fixed.. fuse 20A was burnt/blown.. locks and locks work perfect..... windows are still not working...
Old 09-02-2015, 09:53 PM
lustworld's Avatar
I tested all the fuses... wiring not completely... on the passenger i connected it straight to the battery. . It wotked for a while but it stopped going down, it only goes up for some od reason
Old 09-02-2015, 11:22 PM
because you need to reverse polarity at the battery when playing with the regulator to make it move the other direction
Old 09-03-2015, 08:15 PM
Jimi Hondrix's Avatar
Test power window relay..should be #24 under dash panel. Read this: https://honda-tech.com/honda-civic-d...oblem-2736392/
oneheadlight
16
09-13-2016 03:05 PM
mimog3
02-20-2016 05:20 PM
lustworld
07-23-2015 07:20 AM
empi99
10
07-07-2015 05:40 PM
bks84
07-12-2013 01:24 PM
Quick Reply: Power Locks Not Working, Windows, sunroof 1996 civic ex coupe
