No Crank when Hot
No Crank when Hot
I'm having a problem with my 96 Honda Civic hx, when ever it's hot after a drive or even in the afternoon it will not start no cranking or anything I will always have to jump it to get it started. I've replaced the battery, alternator, and spark plugs and spark plug wires and still the same problem it someone can help that would be awesome.
Re: No Crank when Hot
Manual or automatic transmission?
Starter had bad solenoid only? What procedure did you use to check both the starter and solenoid?
Say, you removed the starter from car and it doesn't turn over at all, then you replaced the solenoid and the starter appeared to work as it should but, is it?
Did you manually spin the starter shaft/teeth in both directions? It should only spin in one direction and if it spins in both it has a defective starter drive.
Read these:
http://www.knowyourparts.com/technic...ter-diagnosis/
http://www.aa1car.com/library/1999/cm119948.htm
Read these:
