Fog light issue some please help 95 civic!
Hello guys i ran out of idea idk where to go to i look up guide and everything!
Okay so i bought some aftermarket fog lights for my honda civic 95
I connected them all basically The only thing that isn't working is the power cable. I connected to the fuse box but no power then i tryd to splice with the fuse of the cluster light and it worked but my wires got really hot i guess not enought voltage and only one fog was working barley showing light so i took it off quickly before i blew a fuse then i try to connect it directly to my igonition switch and only the fog light switch work but the fog light didn't turn on idk what to do i ran out of idea can anyone help me please! What type of power source can i use for the wire??
I would splice it to the coner light but idk how to!
Please help!!!
Please help!!!
Re: Fog light issue some please help 95 civic!
I tested to see if i can wire it to my ignition, and it worked but only the switch light turn on, my fogs didn't i have no idea what else to do! Everything is right has ground. No idea what else to do
Loves Tossing Salad
Are they cheap fogs from eBay? Try hooking it up straight to a 12v source (battery) and see if they work, first and foremost. This will get you acclimated to the type of circuit the lights require. Is it a 2 or 3 prong switch? Based on your description, it sounds like a three. Are the prongs labeled?
It's 3 one for the ground one to connect to the harness and another for a power source I'm guessing which that one was to be on the fuse box , which i did but no type of power
I never narc'd on nobody!
<p>https://honda-tech.com/honda-civic-d...agram-2526151/</p><p>It's amazing what a little bit of searching can find you.</p>
Here is a better understanding
When i try to connect it to the fuse box it doesn't work the switch light don't even turn on
But if i rig it to a fuse the cluster fuse the switch turns on and one of the fogs turns on very dim thought and the wires get suuppper hot so i take it off quickly
It works like this! The right fog turns on but very dim and the wires get super hot so can't do it like this I could blow a fuse or worse guess not enough power
There fog light switch! Turns on
These are the three wires one connected to a ground and the other to the harness the other one well the yellow is what I'm having problems
Sorry the pictures are not in order but hope this give you guys an idea cause I'm out of ideas!!! 😔
<p>Unplug everything. Remove everything. Take pictures and show us exactly what wires and connectors you have. If wires are getting hot, that means you're trying to push way too much power through them, which is a recipe for a fire. Stop that.</p>
But yeah i stop doing that with the fuse just wanted you guys to have an idea
Just trying to figure out what I'm doing wrong. Everything is connected right i triple check it
<p>
</p><p>Don't bump until you've followed through with questions and requests posed to you. We aren't psychics. If you don't give us information, we can't help you.</p>
</p><p>Unplug everything. Remove everything. <strong>Take pictures and show us exactly what wires and connectors you have.</strong> If wires are getting hot, that means you're trying to push way too much power through them, which is a recipe for a fire. Stop that.</p><p>
Loves Tossing Salad
Show me the switch with the labels and how you wired it up, labeling what each of the wires go to. Let us finish this Jason.
EM1Guru
11
10-24-2003 06:57 AM
