Grinding noise and clunks... what is going on here?
Okay so
98 EX coupe manual trans
It's made some noise in the front end since I bought it - the control arm bushings are all decent as is the sway bar. Are there bushings in the steering rack? If so - how do you get to them? I can't see anything under there.
I noticed recently it started making a grinding sound at speed. If I take it out of gear, it doesn't make the noise anymore, only when in gear. I'm not sure if it's a grinding or a vibrating, but it's pretty obnoxious and I'm not feeling too confident in it now.
Where do I start?
Where do I start?
Steve at Heart
Re: Grinding noise and clunks... what is going on here?
Could be a wheel bearing, try jacking the car up and spinning the tires listening for a crunching noise as the wheel is rolling.
Both of those were replaced 5,000 miles ago by the techs at work.
It also doesn't go away when I turn the wheel one way or another. Probably safe to rule those out.
Well then. I'd rather that not happen, considering this trans was just installed by a shop with a 1 year warranty.
I guess I'm bringing it back on Monday.
-DC2-
11-14-2007 08:24 AM
david
11-07-2005 09:24 AM
