D16z6 moderate performance build
Old 08-30-2015, 11:02 AM
Darrell Woods's Avatar
Default D16z6 moderate performance build
Issue: pistons, I am trying to Find a Stock compression ratio, Well Made, Not Ridiculously Priced, full floating wrist pin, skirts coated, stock bore (75mm) piston and high-performance rings. Anyone got info PLEASE reply
Old 08-30-2015, 01:00 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: D16z6 moderate performance build
<p>This is a tech section, not a shopping section.</p>
Old 08-30-2015, 05:16 PM
I was looking for ideas bro...
I was hoping someone could steer me in the right direction..
Old 08-30-2015, 05:56 PM
NotARaCist's Avatar
<p>It's very clear what you want us to do for you. &nbsp;You want us to do your research. &nbsp;That's not what we do here. &nbsp;It's no secret who makes good pistons. &nbsp;It's also no secret that damn near all aftermarket pistons will have exactly what you want. &nbsp;You want specific part numbers, go find them.</p><p>Wiseco Manufactures High Performance Forged Pistons &amp; Performance Parts for Motorcycles, ATVs, Snowmobiles, Marine, and Automobiles</p><p>http://www.cp-carrillo.com/</p><p>&nbsp;</p>
Old 08-30-2015, 08:42 PM
theYBLEGAL's Avatar
Dude on ebay sells nippon cast pistons, coated skirt, floating pin capable (he machined mine for them), stock comps available. This dude's listings http://www.ebay.com/itm/JDM-NIPPON-R...-/181643039051
Same bore? Usually you will have too much ptw clearance. Unless you are starting with new sleeves...
I'd recommend bore .25 over...
Old 08-30-2015, 08:44 PM
Dur Da Dur
hondur's Avatar
if you want "not over priced" get supertech pistons, people seem to use them alot without problems. If they don't come coated, then find a coating company and get them coated along with your crank and other engine parts. you can have both skirts and tops coated with different teflon formulas (or whatever) to maximize performance.
Old 08-30-2015, 08:45 PM
Dur Da Dur
hondur's Avatar
Originally Posted by theYBLEGAL
Dude on ebay sells nippon cast pistons, coated skirt, floating pin capable (he machined mine for them), stock comps available. This dude's listings JDM Nippon Racing P30 B16A B20 vtec Piston Set Sir II NPR 84 5mm Big Bore New | eBay
.5 over is way more common and it'd increase ring selection if nothing else.
Old 08-30-2015, 08:55 PM
theYBLEGAL's Avatar
.5 over reduces your wall strength and the number of times you can rebore. But to each their own.
Old 08-30-2015, 09:09 PM
Dur Da Dur
hondur's Avatar
yeah, thats true and all, but d16s are a few hundo.. going from .25 to .5 pistons is going to cost more than replacing the short block and reusing the .5 pistons... i mean, the engine itself is going to be cheaper than the rotating assembly, machine work, or turbo system.
Old 08-30-2015, 09:15 PM
theYBLEGAL's Avatar
If I ruined my cylinders, chances are high the pistons are shot too. I get machine work cheap. And I'd rather know what I have than gamble on a used block.
Thats the, to each their own
hoffdaddy
02-04-2015 05:54 PM
n20sol
07-02-2005 06:34 AM
daniboy4nspd
05-23-2003 10:53 AM
AztecRacer
12-29-2002 08:07 PM
Quick Reply: D16z6 moderate performance build
