front tires uneven wear
good day guys,
my civic sits with both tires in front sticking out so the inside sidewall rubs on the road and making tires wear out faster. could this be a UCA problem? what suspension part do I have to look out for that needs to be replace. Thanks
PHANTOM MENACE
Re: front tires uneven wear
Alignment first. People will always say it's toe that causes uneven wear so make sure it's all straight. Then if you feel the need adjust camber.
For the record I say it's both, I'm not one to blame tire wear solely on incorrect toe.
X2 but OP didn't say how low he is. So he could be lowered 4in and that's when camber becomes a problem. But anything other than that a good alignment will correct it.
I never narc'd on nobody!
<p>Inside sidewall rubs on the ROAD? What the ****? How did you not realize that something is quite clearly broken? Stop driving the car right now. That's painfully dangerous. Inspect your suspension components, and figure out what's broken.</p>
PHANTOM MENACE
I'd quote the picture too but I'm too lazy to recapture it with alignment circled. To answer your question it's controlled by how the inner and outer tie rods are attached. There doesn't necessarily have to be something broken for this to result in worn tires but adjustments are typically done via an alignment service performed at a shop. I will say its possible to do this at home but accuracy may not be as good as it will be when having it done by a shop equipped to perform this service.
<p>A DIY alignment involves 8 jack stands, 40 feet of string, a ruler, high school math skills, and 6-8 hours of time for someone who has never done it before. Or, you could just pay a professional the $80 to do it for you in an hour. I don't know about you, but I value my free time at a hell of a lot more than $10/hr.</p><p>Take it to an alignment shop. Let them do the work. If they tell you something is broken (which, unless you were exaggerating, something is broken), decide from there how much you value your time.</p>
averyvm
Suspension & Brakes
11-02-2009 10:32 PM
jxhxb
08-16-2008 05:22 PM
Understeer
Suspension & Brakes
06-29-2005 05:09 AM
Kyles ej1
01-08-2005 04:07 PM
