Are all the d series driveshafts identical?
Hi everybody. I'm new to this site, hope there isn't another thread with this question because if it is, I couldn't find it. My question is: Are all the d series driveshafts identical? I have a 94 Civic eg3 with d13b2 (Europe model). I'm considering replacing the driveshafts and I want to know if I can take them from a d16z6 Del Sol. I already swapped the knuckles with the ones from the Sol i was talking about, keeping the original d13 driveshafts so i know that this isn't a problem, but will they fit on the other side? Thanks!
Technical Hero
Re: Are all the d series driveshafts identical?
I can't speak for the d series in other countries but in the US the 92-00 d series axles are interchangeable. The only difference would be if your car had ABS it would have a tone ring on it and would need to be swapped over if the donor axle didn't have it.
My car and the donor both lack the ABS system. I guess there's no difference between USDM and EDM models mechanically speaking, just that the d13b2 1.3 16v 75HP PGM-Carb engine which I have was sold only in Europe and maybe Japan (not sure though).
All dseries from 92-00 call for the same axles. Even whether it's automatic trans or stick is irrelevant. Only difference would be the abs ring
Thank you both for your answers. I just needed to confirm the rumor that I heard before disassembling half the car...
What kind of mis-information is this?
no, EG and EK axles are not the same.
Yes they "fit".
OP, del sol fits into EG *chassis* style, so yes, you have axles to swap. do work!.
Others puking incorrect information. Do a google search yourselves.
EG and EK have different compressed and non-compressed axle lengths.
There is a reason EG and EK do NOT share subframes even.
Yes they "fit".
I just went to tech parts express last week. I bought axles for my 99 manual trans d16. My coworker bought axles for his 94 automatic transmission d16z6. Same exact axles. Same part numbers so where's the misinformation?
92-00 d16 share axles
Left 773-708
Right 500-505
88-91 d series have different length axles than 92-00
Left 773-708
Right 500-505
honda oem part number
found MY misinformation
OBD0 versus OBD1/2
between OBD1 and 2 only a few millimeters driverside, but passenger side has a bigger difference between eg and ek
OBD0 versus OBD1/2
Hoping you could clear this up for me?
PM the user, this thread is from 6 years ago and the user may or may not be active on the site anymore.
hondatech8798
10-16-2012 01:31 PM
turbohenry
03-29-2008 05:18 PM
