94 civic fuel issue
Old 08-31-2015, 02:14 AM
redline it's Avatar
Default 94 civic fuel issue
Stock d16z6 fuel pump will prime but will not stay running replaced the pump a few days ago car ran fine all weekend now will prime start and die if I keep the key in the cranking position it will run until released to run any ideas?
Old 08-31-2015, 04:04 AM
delsolintegra's Avatar
Default Re: 94 civic fuel issue
Sounds like the capacitors in the ECU that control the fuel pump priming circuit are starting to fail. Time, heat and humidity will cause a intermittent fuel pump priming failure until they eventually totally fail. Borrow a known good ECU and swap it out. These ECUs are now over 20 years old. Common problem.
Junkyard about $125.
You could check the main relay solder joints and the ground connection at the thermostat housing but my guess is ECU.
Old 08-31-2015, 05:05 AM
redline it's Avatar
I have a spare Ecu I'll swap in after work thanks
Old 08-31-2015, 09:28 PM
Stancetard Hate Monger
eghatch9295's Avatar
this does not sound like an ecu issue, given as it stays running with the key turned. id lean toward checking your key tumbler/ignition switch.
Old 09-01-2015, 11:52 AM
Former User's Avatar
Yep, sounds like bad ignition switch. The electrical switch can be replaced.
Old 09-01-2015, 01:17 PM
White_EG1's Avatar
X2
Old 09-01-2015, 02:32 PM
PHANTOM MENACE
24TEN's Avatar
Happened to me when I didn't know much about cars, I replaced both and have not had an issue in 15 years. There are testing procedures in the FSM if you want to trouble shoot it properly.
Old 09-02-2015, 01:01 PM
redline it's Avatar
I haven't had time to mess with it since but yesterday it started up ran fine but after stopping and starting a few time while playing with the key it started acting up again.
Any suggested write ups on replacing it?
Old 09-02-2015, 04:52 PM
There should be a diagram in the FAQs sticky for testing the ignition switch.
You should be able to buy the electrical part of the ignition switch on eBay. In the past, I've seen it for about $50.
Old 09-03-2015, 01:52 PM
tamboo's Avatar
is this your key ring? if so get it down to one or two if possible.
Old 09-04-2015, 04:24 PM
redline it's Avatar
Lmao nope not me only car key house key and garage key I hate when people have a million keys on their lanyard
dlx111
08-31-2018 12:27 PM
no_rice_please
Engine Management and Tuning
10-12-2009 09:36 PM
krysted9354
20
04-08-2009 03:32 PM
b16a1sirhb
04-09-2003 11:50 PM
Quick Reply: 94 civic fuel issue
