Heater blower not working
Old 09-17-2015, 07:54 AM
SonicC's Avatar
Default Heater blower not working
Hello everyone,
I'm working on a 98 Civic EX and blower stopped working suddenly. I was doing a coolant flush and had the heat on max. Next day when I started it up there was no air blowing.
I did the following:
- tested blower motor directly and it works
- replaced resistor, but it didn't make difference
- checked (and replaced) the fuse under dash, nothing
- replaced relay under the hood, nothing
Last night I tried it again randomly and it worked until I turned off the car. When i turned it back on it wasn't working any more.
Any suggestions what else to check?
Old 09-17-2015, 09:32 AM
Former User's Avatar
Default Re: Heater blower not working
Test the relay.
Old 09-17-2015, 09:33 AM
SonicC's Avatar
I went and bought a new one, didn't make difference.
Old 09-17-2015, 10:00 AM
The problem is intermittent, so you probably haven't actually ruled out the blower motor with your test. You may want to redo that test multiple times.
Also check whether the hood and dash fuses for the blower motor are loose. You can gently and slightly twist the prongs to tighten.
Another possibility is the switch.
Old 09-17-2015, 10:01 AM
Jimi Hondrix's Avatar
Just a guess: maybe there's air trapped in the heater core?
Flushing it directly may help:
Old 09-17-2015, 10:04 AM
How would air in the system affect the blower motor?
Old 09-17-2015, 10:06 AM
SonicC's Avatar
I've tried the motor few times, started right up every time.
Also checked the fuses, made sure they're snug. Tried putting a different/spare fuse to test.
What switch are you referring to?
Old 09-17-2015, 10:15 AM
Specify the fuse numbers you are referring to or post pictures.
For the blower.
Old 09-17-2015, 10:18 AM
SonicC's Avatar
Fuse that I was checking is #17
Old 09-17-2015, 10:21 AM
Two fuses are required for the blower motor because it is controlled by a relay. The relay requires two power and ground sources - for the relay switch and for the switch activator.
Old 09-17-2015, 10:23 AM
SonicC's Avatar
So the two fuses you're referring to are #17 under dash and the 40A one under hood?
Old 09-17-2015, 10:24 AM
...the 40A one under hood?
#55
delsolintegra's Avatar
I had that problem with my 93 del sol. The blower would work initially but after running a while it would stop. If you immediately went under the hood and touched the blower relay you would burn your fingers as soon as you touched the relay. The relay is good it's just that it overheated because the blower is drawing too much current. When you go under the dash, remove the glove compartment and drop the blower motor. Look at the factory wire connection to the blower motor and you may see a lot of corrosion on the heavy gauge wire just behind the connector. This is a big short that happens after the motor runs a while and heats up the connection. I replace the blower motor with one from autozone and did a hard wire connection and got rid of the factory connector.
A lot of water/condensation collects in that area and settles right on that connector since it's a horizontal surface.
Old 09-17-2015, 10:28 AM
Old 09-17-2015, 10:31 AM
That's why i prefaced with " Just a guess"
I think I got tripped up on the OP's ttile: Heater blower not working.Obviously, the blower motor works to push heat, A/C and outside air.. sorry for my ignorance.
Old 09-17-2015, 10:40 AM
SonicC's Avatar
I'll double check those connectors....
Old 09-19-2015, 06:18 AM
SonicC's Avatar
Figured I'll update this thread...
I found out what the problem was. Took out the fan switch and found out one of the pins in the back of it where wires connect was bent. Not sure how the hell the blower worked at all
Old 09-19-2015, 08:19 AM
Thanks reporting the solution. Maybe it will help others that encounter a similar issue.
Allen Harris
11-20-2016 07:00 PM
v8killaz
10
09-15-2014 04:28 PM
themadness
Honda Civic (2001 - 2005)
14
02-06-2011 01:36 PM
JDMPR
10-15-2009 01:00 PM
NatedoggAZ
12-03-2004 02:17 PM
Quick Reply: Heater blower not working
