Won't start
Old 09-04-2015, 08:48 AM
Lastman's Avatar
I got power to alt starter fuse box . Headlights don't work nothing comes on HELP.1998 Honda Civic stock
Battery fuse is good ign fuse is good showing 9 volts in fuse box under dash
Old 09-04-2015, 01:16 PM
Former User's Avatar
Default Re: Won't start
Should your thread title actually say "won't crank"?
Originally Posted by Lastman
showing 9 volts
Dead battery?
Old 09-04-2015, 01:23 PM
I never narc'd on nobody!
NotARaCist's Avatar
<p>Stop quoting random ****. &nbsp;Use complete sentences so we can actually understand what the **** you're talking about. &nbsp;Does the car try to start, but fail, or does it not try to start at all? &nbsp;What voltage do you get across the battery terminals?</p>
Old 09-04-2015, 01:24 PM
9 volts
Old 09-04-2015, 01:58 PM
f15Civic's Avatar
9v seems low you should have 12-13v in order for the engine to start. Also have you checked all the ground points?
Old 09-04-2015, 03:19 PM
SteveT2008's Avatar
9V!! your battery is not only discharged but also pretty sure it's dead. An acid battery under 11V, even "empty", is never a good sign.
Old 09-04-2015, 03:31 PM
Lastman's Avatar
Default Car does nothing
98 Honda Civic has a good battery. Has 12 v going to the alternator and starter. Has 9. V to the fuse box ignition fuse is good battery fuse is good. What could it be also nothing come on when the ignition is on no dash light head tailights nouthing also this is my first time here give me time get the way it's suppose to be done thanks
Old 09-04-2015, 03:47 PM
Fish Twig
tony_2018's Avatar
Default Re: Car does nothing
Check fuses.
Old 09-04-2015, 03:55 PM
Lastman's Avatar
What other fuses can I check besides what I named
Old 09-04-2015, 04:14 PM
NotARaCist's Avatar
<p>You already have a thread. &nbsp;Don't make multiple threads.</p><p>https://honda-tech.com/honda-civic-d...start-3257904/</p>
Old 09-04-2015, 04:15 PM
Lastman's Avatar
Last thread they complained it was incorrect sorry
I just need help and u guys seam very knowledgeable
Old 09-04-2015, 04:20 PM
NotARaCist's Avatar
<p>So you created a new, equally shitty thread? &nbsp;That's not how it works. &nbsp;Quit with the multiple posts, quit with the quoting random ****, quit with the useless posts. &nbsp;Use full and complete sentences, and type in a way that actually makes sense, instead of the keyboard diarrhea you're doing right now. &nbsp;Punctuation is your friend.&nbsp;&nbsp;Stick to tech, and stick to one thread. &nbsp;This is basic netiquette stuff.</p><p>&nbsp;</p>
Selena781
04-22-2014 06:52 AM
dc2teg2006
03-28-2009 05:31 PM
seamus657
03-06-2009 08:47 PM
braypunt
22
09-11-2005 09:10 AM
Train
06-02-2004 08:15 PM
Quick Reply: Won't start
