B18C idles at 1500 while rolling, 750 when stopped.
Old 11-05-2010, 05:45 PM
Rok_Stok's Avatar
Default B18C idles at 1500 while rolling, 750 when stopped.
1994 Civic Si, '97 JDM B18C GSR swap, Y21 LSD tranny
OBD1 to OBD2 jumper harness, OBD2 P72 ECU
When I drive around and put it in neutral to coast it idles at 1500 rpm, I have to come to a complete stop for the idle to go down to 750 rpm. Anybody know what's going on?
Old 11-05-2010, 06:00 PM
EJeff8's Avatar
Default Re: B18C idles at 1500 while rolling, 750 when stopped.
Your brakes put strain on the engine.
Old 11-05-2010, 06:01 PM
EJeff8's Avatar
Also, why do you need the jumper? Both the engine and ECU are OBD2.
Old 11-05-2010, 06:23 PM
Rok_Stok's Avatar
Yes, but my car has an OBD1 engine harness, I can't use the JDM engine harness because it's made for a RHD vehicle. Normal idle is 750 rpm, so it comes down to normal when I come to a complete stop. I'm wondering why it idles at 1500 rpm while I coast in neutral. It should idle at 750 rpm while in neutral no matter what.
Old 11-05-2010, 06:55 PM
whiteboyGSR98's Avatar
perhaps take off the idle control valve and clean it out... my single did that and cleaned it worked for a little ended up having to replace it
Old 11-05-2010, 07:14 PM
delsolo95's Avatar
Any CEL?? Are vaccum lines connected right??
Old 11-05-2010, 09:59 PM
Rok_Stok's Avatar
Okay I'll try that, I have a spare GSR IACV laying around just in case too.
Originally Posted by delsolo95
Any CEL?? Are vacuum lines connected right??
No CELs, I got rid of them both today lol. They were 17 (speedometer) and 41 (header o2 sensor), which are unrelated. Vacuum lines are all hooked up, I checked them many times because there's a ton since I'm running the stock GSR intake manifold.
I did reset my ECU after I fixed my VSS connector and plugged in my o2 sensor today. This is my first time to run an OBD2 ECU, maybe it needs time to learn? Any ideas?
Old 11-06-2010, 08:43 AM
Rok_Stok's Avatar
Well I fixed it...
Today I started the engine and it idled at 1500 rpm constantly. I found that the screws were backing out of the TPS, problem fixed.
Old 11-06-2010, 02:17 PM
delsolo95's Avatar
Originally Posted by Rok_Stok
Well I fixed it...
good to know!
Old 11-06-2010, 02:42 PM
Mad-Mike's Avatar
My em1 does the same thing.
Old 11-07-2010, 06:09 PM
court76wi's Avatar
That's normal. I don't know about all Honda's, but most of them have a rolling idle and a standing idle. My 89 CRX and 97 GSR both have a faster idle when the car is moving.
I don't know if it's to help with shifting or prevent the engine from bouncing/surging, but my Integra service manual even mentions the two separate idle speeds...
Old 11-07-2010, 08:12 PM
Rok_Stok's Avatar
Hmm, never heard of that before. It ended up being my TPS, it was almost off the manifold.
Old 11-08-2010, 05:13 AM
fsp31's Avatar
That's right. My 97' B18Cr does the same thing. I even drove for a short time without the brake booster connected (blocked the hose to the manifold) due to a malfunction. Idle was not affected at all.
Delsol-Yuuup!
06-03-2012 04:50 AM
pork
09-24-2007 09:46 AM
the.hamburglar
04-19-2007 11:19 AM
sleepyEK
09-03-2005 01:22 AM
SPiFF
11
09-02-2005 05:32 PM
Quick Reply: B18C idles at 1500 while rolling, 750 when stopped.
