B16a2 and auto-to-manual swap in 97 Civic! Starter won't crank engine! (solved)
Ok guyz I just did the swap in my 97 ek. but when i turn the key to the starter doenst turn over.. i just get a rapid, repeated clicking noise from my relay/fuse box under the hood... i need some serious help man lol. im suppose to be racing my cousin on saturday! my gurl supppose to be riding shotgun and isnt goin to give me nun if i cnt even make it to the track lol.
Re: B16a2 in Ek with auto to manaul swap! PLEASE HELP No START!
nd its not the battery or starter. the swap started fine before i pulled it from the Em1. also a brand new battery. someone told me to check my grounds because that could be the problem but idk how many there are! lol i only see two nd both are grounded.
theres 3 one on the trans, one on the front to the valve cover and one to the battery. nothing that had to do with makin a car a 5 speed would stop it from running, the onlywireing you should have to do is for reverse lights and clutch engagment switch
ok i didnt know about the ground on top of the valve cover. nd there is a ground that bolts to the themostat housing but i dont see one on top of the transs..i didnt hook up the reverse lights yet soo thats not a problem and i soldered the two thick black wires and the black/blu wires together so that the car thiinks its in park so that should be right.. would those two small grounds really cause the starter not to turn over tho? thankzz btw
Re: B16a2 and auto-to-manual swap in 97 Civic! Starter won't crank engine! (solved)
yea no problem, u were missen 2 grounds and even though he car starts doesnt mean it runs right, i had my car dynoed last week. had the stck grounds in all 3 spots, in high revs it ran like ****, got 2 gauge wire and made 3 new grounds and the breaking up went away and we completed the tune!!
ludarabota
11-28-2010 09:44 AM
unabonger
24
04-03-2003 07:11 PM
