eg civic wont spark?
ok so i been trying to figure out why my car wont start i put the motor in and wanted to start it and i got nothing ...
what i checked
fuses all good
their is power going to the distributor
and i already swapped distros with a buddy and my distro started his car fine so my distro is good
heres a video
any help is appreciated
what i checked
fuses all good
heres a video
Re: eg civic wont spark?
yeah i unplugged a spark plug wire and held it out and put a spark plug in it and turned the key but i got no spark ... and my fuel pump doesn't prime and i put a wire in the plug to get the get the codes but got nothing
Did you attach the G101 ground wire to the thermostat housing?
yeah i onced its unplugged i held it to the valvecover bolt and no spark ... the ground is bolted on yeah couse i believe thats a main ground right
the hood fuse is good but the dash fuse i have a question ... wat voltage is fuse 24 10 or 15 and is it the one on the lifted portion of the fusebox
no the fuses are good .. idk if the fact that my car was converted from auto to manual would have any affect on it ? and from the underdash harness theirs a harness unpluged on the upper corner that has seven wires
With the key in ON(III), the starter cranks the engine, right?
Check whether voltage from fuse 31 and 24 reaches the main relay plug. If so, resolder the main relay:
http://techauto.awardspace.com/mainrelay.html
im sorry but which is fuse 31 i dont see in the diagram? and ima check the main relay but ... wat wires carry the power ?
ok my main relay is good and none of the fuses r blown i switched the main relay off my coupe and it started the coupe but still the same on hatch so idk
well when i used the light to check if their was power to the main relay the gas pump purged ... u mean bolted on? does the engine fusebox have to be ground becouse i got one bolt on it
the green with a yellow line wire on the main relay that is for the main relay when i connected the light to see if there was current to it the light was very dim... does this mean their no a weak power going to the fuel pump ?
well i got my car started 2day i guess one of the plug wasn't making full contact well thanks for the help sorry for the trouble
97accord_R
08-30-2009 06:51 PM
