96 civic temp gauge problem
I have a 96 civic cx hatch that has had multiple engine swaps from b16,gsr,ls,type r and finally ls-t. The car has always had a problem with temp gauge not working correctly I have tried multiple clusters and needle broke on few. When i put the key on position 2 temp jumps up to middle and then when I turn on the car it goes up all the way to H as the cars warms up and stays there? My radiator fan dont come on by itself as well so I just jump it at the fan switch so its always on due to me never knowing the real temparature. I have traced temp wire yellow green from switch to cluster and seems to be good.
If anyone has any imput I surley would apriciate it. Thanks
Re: 96 civic temp gauge problem
there are three sensors when to comes to coolant temp. your fan problem and gauge cluster problem are probably not related.
1-wire sensor under the dizzy controls the needle on the cluster
2-wire sensor under the dizzy sends ECT to the ecu.
2-wire switch in the thermostat housing controls the rad fan.
test the gauge cluster wiring and sending unit like this:
then report back
then report back
You need to check for a short not an open (broken wire).
Start by unplugging the 1-wire sending unit under the distributor. Does this make the cluster temp gauge needle stay at Cold?
If the wire running from the sending unit to the cluster does not have a short (continuity to body ground), then the cluster or temp gauge is bad.
So the 4 clusters I have changed were all bad? i had a dx ex si and now ctr cluster they all cant be bad. I mean the gauge goes back to 0 when car is shut off is spikes to middle when key is turned.
Unplug the cluster and the sending unit and measure resistance to body ground from either end of the wire using a multimeter. This will tell you whether there is a short, which seems likely based on what you have said.
I cut plug from spare harness spliced it to a new wire ran it to gauge cluster cut the cluster wire and same outcome, spikes to middle even with new wire ran to it. I left cluster wire cut, still spikes to middle with nothing connected to it.
The short must be in the cluster connector with sending unit wire. Carefully inspect that connector and the terminal for the sending unit wire for damage.
Another weird thing even with the cluster plug with Y/G wire unplugged still spikes lol but when the one on the left is unplugged it drops
Ok you know what im having my friend bring his midori EK tomorrow I will put his cluster in and I can bet on same outcome, if so what you suggest from there?
