norcarsol's 93 Del Sol build
norcarsol's 93 Del Sol build(splattered,tucked)
very much a noob on here but have been a follower for quite some time and finally decided to go ahead and register.i will say this site takes alot of my time just researching and alot of the cars have inspired me on things to do
keep up the good work everybody!
So I just recently picked up a new project(1993 del sol) from a buddy on carolinahondas.com and figured i'd go ahead and start me a build thread to show my progress on it as i go.when i got the car it had a f20b swapped in it.the f20b will be swapped out with a poor man type r,and the entire car will be completely redone and please do not copy my engine bay as i have a ton of time in it and was going for something unique but do enjoy and post all comments and opinions good or bad you won't hurt my feelings!!
sorry for such shitty quality pics the majority were taken with an iphone but better ones coming soon!
Future plans for vehicle:
wire/brake/fuel/clutch full bay tuck(in progress)
fresh wheels
rear disc conversion
fully build the b series swap
turbo setup
different suspension setup(is on ebay coils and camber kits good enough for now)
body work and full exterior paint a different color
possibly get shop/company sponsors
and hope for a detailed ad in honda tuning or other magazines
How it was the day i brought it home
pulled the f20 out and traded for this poor man r valve cover will be redone and such but this is how it was when i got it
Then started yanking brake lines and wiring to start prepping for engine bay paint
Dash and ac/heat setup had to come out for proportion valve relocate
Semi Gloss black base coat (rattle can)
Then laid a little splatter over the base coat and several layers of clear to protect it
this is my newest addition to it got some minty s2k leathers and did a complete delsol pan and rail swapover so they're held down by all 4 bolts if you'd like more info or pics on this i have some of the process very easy to do just time consuming
Test Fit have full interior it's just pulled so i could clean everything really good
latest update got brake lines and bulkheads and have about completed the brake tuck
pics are just to mock up lines haven't been tightened down and prop valve not mounted legit yet
Update as of 11/15/2010
tucked headlight harnesses today and reassembled front end
passenger side
driver side
under driver's fender with windshield wiper harness tucked through as well
done for the night
update 11/17/2010 fuse block relocation(shoutout to stevenson_18 for the idea)
that **** wasn't any fun
isn't mounted secure yet but it's in it's location
So still in the process of doing my brake line tuck and ran for my rear lines today drilled up through the exhaust tunnel to run 90 degree bulkheads so i can run my rear brake lines down my center console. and disregard the exhaust hangers as they came on the car like that and will be replaced when it comes down to it but just testing the fitment for now also plan on using a little heat wrap around the lines for protection since it's right near exhaust shouldn't get too hot way back there but keeping it safe also took sheet metal and self tapped it to the frame rail over where the lines cross to protect them from scraping.interior lines and front lines will be ran tomorrow so more pics then but for now...
And here are some other random pics of the car i took on my friend's camera
so that's all my progress so far will be updated regularly with progress
thanks for viewing
fresh wheels
turbo setup
passenger side
driver side
done for the night
thanks for viewing
Re: norcarsol-delsol build
and the splatter is craft paint
just cleared over for protection
and the updates are the brake lines at the bottom just did that yesterday
engine wire tuck and headlight harness tucked coming this weekend.
and i'm just gonna go with black valve cover
thanks for the input bud
would like to see some of you guys build threads as well
thanks man
yeah will be alot more upated this weeken
and not a whole lot
the brake tuck is really simple
worst part of mine was pulling dash and heater/ac box
but theres a place here that makes custom brake lines
and what i did was bent coat hangers the right length and bends
and they made the lines exactly how the hangers were
got 45$ in all lines fittings.
Re: norcarsol's 93 Del Sol build
you can get anything for a b series new or used
f series just makes things kind of a pain in the a$$
and i'm a firm believer of the b series head for boost
haha
if you know of some i'd like to see them really
thanks for the input though
you gotta build thread?
would love to see more sols
