95 civic hatch - When headlights are on, the passenger brake light won't work
Ok ii bkno I seen this somewhere but I go to look at it again but can't seem to load the page sorry for a repost.I gotta 95 civic hatch and when my headlights ar and I hit the breaklight my passanger light goes out but when the headlights are off the breaklights work fine. Wat couuld be the cause of this any suggestions whould be appreciated
Former Moderator
Re: weird breaklight problem
Double check to make sure that you have the correct bulbs in all the slots, such as make sure you do not have a double post 1157 bulb in a socket designed for the single post 1156 bulb, etc. etc.
Re: 95 civic hatch - When headlights are on, the passenger brake light won't work
i checked it.the bulb is correct but i noticed the wires were cut and crimped together and that it seems like its loose inside the socket its self when i move it it works back to normal so im trying to figure a way i can fix this issue now but thank u....any ideas on how to get the wire to stay in the socket itself?
Bulbs are correct just Realized the harness was cut and crimped togather for some reason?and that when i move the wire it works fine just seems the wire is loose inside the socket itself any ideas how to get it to stay?
Oh look, I can change this
It's likely a bad ground in those wires. When it's not grounded properly, funny things happen since power will ground through some other path and cause all sorts of weird electrical problems. I've seen Ron@HT diagnose these before. But, first off fix that bad connection and see if your problem goes away.
92VXeg
09-02-2008 05:28 PM
Kenshinhimurasz
Honda Civic (2001 - 2005)
09-26-2007 02:26 PM
