civic si newly chipped
my cel went on a bit ago and it was my ecu chipped that fryed. got it rechipped but cel is still on. is all that is needed is a ecu reset or do i need to test codes again.
thanks for the help
thanks for the help
Re: civic si newly chipped
I would disconnect the battery for 5-10 minutes to clear the CEL. Then start the car and drive it and if the CEL pops on test again for codes.
i pulled the ecu fuse for 15 min and then let it run and cel is still up. should i take it off the battery instead of removing fuse?
**** it ill just check the code again
TwoKSiR
Engine Management and Tuning
08-01-2009 08:05 AM
