Tension timing belt
Old 11-09-2010, 04:51 AM
Jimster480's Avatar
Default Tension timing belt
Is there a way for me to tension my timing belt without taking off the covers? Its getting really loose now after 16K miles.
Old 11-09-2010, 04:56 AM
Jockone's Avatar
Default Re: Tension timing belt
Should be a gromit over the hole in the cover to let you get to the tensioner bolt to take up any slack and adjust the belt.
Old 11-09-2010, 06:48 AM
Jimster480's Avatar
Yea but if i loosen it, how does that make the belt tighter?
Old 11-10-2010, 04:55 AM
EE_Chris's Avatar
When you loosen the bolt, the tensioner spring + rotating the cam 3 teeth will provide the required amount of tension on the timing belt...then re-tighten the bolt.
Old 11-10-2010, 07:37 AM
sde780's Avatar
there's a hole in the lower cover for a 14mm
take off the top at least so you can be sure you tightened it properly, it takes all of 5 min with a 10mm
Old 11-10-2010, 08:29 AM
Former Moderator
B18C5-EH2's Avatar
Year/make/model/trim level of vehicle? Engine?
If you have not removed any covers how do you know the belt is loose?
Old 11-11-2010, 08:04 AM
Jimster480's Avatar
97 EX, Built D16YZ (Y8Block/Z6 head). I know its loose because I pulled the cover off the other day when I pulled off my valve cover to change the gasket. And its pretty damn loose. Actually scary how loose it is. I'm not sure how it got this loose but now I need to fix it. I have both the top and bottom cover on.
LI-HONDAGUY
Honda Civic (2001 - 2005)
12-28-2018 04:30 PM
mattatchison
06-07-2007 04:58 PM
JDN169
11-07-2006 07:49 AM
ranta18
07-09-2003 12:41 PM
Luserkid
04-10-2003 06:41 PM
Quick Reply: Tension timing belt
