00 hatch/OBD1 GSR motor - Throwing codes #9 & #20
ok guys i need to get this stuff corrected so i can go get the car registered its a 00 civic hatch running and obd1 gsr with obd 1 everything and an obd1 ecu....im also running a chasebays harness so i know some is removed and what not anyways i grounded d4 and the car is throwing codes #9 which i know is the cylinder sensor and #20 which is electronic load sensor....how do i resolve these codes much thanks for the help guys
Re: THROWING CEL PLEASE HELP ASAP!!!!
cel 9 is cyl position sensor which is located inside the distributor. I would check the wiring connections and make sure the are connected correctly. cel 20 is the ELD which is part of the engine bay fuse box. Cel 20 can be disable if your ecu is chipped.
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
dont know how to change the title and yeah i downloaded the gsr helms maunual and i have to perform some resistance tests worse comes to worse im going to have to replace the whole dizzy which is $$$ and yeah i noticed i cant really take care of #20 until i get a chipped ecu cause im just running the stock p72, but it really doesnt affect the performance so i can live
ok got it does anyone know where i can find the right wire order just to double check all the wires are in the right order
Re: 00 hatch/OBD1 GSR motor - Throwing codes #9 & #20
ok well i used my friends advantage to measure the readings from the dizzy signals and they are bouncing around within and not within spec according to the helms manual it said there should be between 350-700 ohms and mine was reading about 345 ohms, which i assumed was still close, so i checked the voltage and the frequency of the signal and it was a little low to normal so im assuming i might have to replace the dizzy....another thing i noticed was unignited gas was coming out of my header which obviously is not good at all....will replacing the dizzy help cause of the sensors??...I know all the cylinders are getting spark as i pulled the plugs off the dizzy to make sure they arched which they all did. also tested the spark plug wires so they are all good
and there is also a little oil getting in cylinder 3 but its worse and the unignited gas is coming out of 4
i have the whole helms manunal that i went by...so im going to replace the dizzy to see if it fixs the problem according to the manual i have to replace it so ill see
