95 hatch auto has a manual ECU - shitty gas mileage
I just picked up a 95 DX hatch (automagic) to use as a DD. It's surprisingly in decent shape, and runs pretty well with its stock D15B7. It does get somewhat shitty gas milage tho...but that could be an old O2 / cat thing. I'm gonna replace those and see if the MPG increases.
However, while troubleshooting my AC clutch not kicking in, I found that it has a manual ECU (P06-A02), where it should have an auto ECU (P06-A52).
Would it be okay to leave it? I have no cel, and like stated, it seems to run fine.
Any insight would be much appreciated.
TIA
JAP
TIA
JAP
Re: Wrong ECU in my 95 hatch
-Do an ignition system tune up.
-I would think that the engine rpm where the auto transmission chooses to change gear is non-optimal without an auto ECU. This may also contribute to the low gas mileage.
Seagull Management
Re: 95 hatch auto has a manual ECU
I'd definitely replace it, automatic P06s aren't worth much.
Check and see if i's just the ECU case, I've seen some that had guts switched between cases for some unknown reason. There should also be a sticker identifying the board on the grey ecu connector, inside the case. Ideally the board sticker and ecu case sticker would match, but this is not alsways the case, I found out the hard way.
Originally Posted by 94EG8
Define shitty mileage. When I swapped the automatic out of my sedan for a DX 5 speed I picked up about 100km/per tank. I never actually checked actually mileage till after I swapped the tranny and at that point I as getting around 40US MPG. If you're used to driving 5 speed civics be prepared to be underwhelmed as far as fuel mileage goes.
Originally Posted by RON@HT
Also, what did your tune up consist of?
Originally Posted by jayWknight
If you are going to sell the manual ecu, I will take it off your hands.
EGandDArida
11
10-01-2008 07:49 AM
