Idle problem with mini me swap
97 civic (d16y7 with y8 head) with mini-me swap, idle problem
Hi everyone,
I just did a mini me swap and i'm having problems with the idle. I am currently using the p2e ecu and lx fuel injector that came with my car. nothing is getting better, i also check the tps and map sensors, swapping back and forth, nothing is working. I'm currently planning to do the rpm switch vtec thing when the car runs normal. I will get a p2p ecu later, i just want to make my car run normal. any information will help?
Part list:
y7 block
y8 head, using the y8 head gasket.
y8 manifold with y7 tb, using the y7 gasket and the manifold is from a 99 civic but i blocked off the air assist ports already.
p2e ecu
y7 fuel injectors
Part list:
y7 block
p2e ecu
y7 fuel injectors
Re: Problem with mini me swap
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
What kind of idle problem are you having?
Any CEL codes?
Any CEL codes?
uindaway
13
11-01-2012 01:05 PM
max23
10-18-2005 06:14 AM
SPOON_BeIgHtEeNsEe
20
03-18-2003 08:39 PM
