OBDII b20b in a del sol?
will this work in my sol i know the motor is a obd2 motor and i have a obd1 harness( my del sol is a 94) will it all plug up?? also can i still use my p28 ecu?? also the motor dosent come with a dizzy.. what dizzy could i use so it all matches up and connects good?? thanks
thanks
thanks
Re: b20b in a del sol
I would suggest getting a ls obdI ecu or a chipped ecu for the b20. Ul need a obdI dizzy, obdI alt, obdI injectors, or u can just use a 96-2000 integra harness that will mate all the obdII componets to ur obdI ecu. You can use the p28, itl run it but I wouldnt due to leanin out up top and so on.
Thats a misconception that keeps getting spread around. It does not matter what OBD it is. There are two types of injectors, "Peak and Hold" and "Saturated."
1988-'91 Civic Si/CRX Si Peak and Hold 240cc
1992-'95 Civic Saturated 240cc
1996-'00 Civic dx cx and lx Saturated 190cc
1996-'00 Civic ex/si Saturated 240cc
1990-'91 Integra RS/LS/GS Peak and Hold 240cc
1992-'00 Integra LS/GS Saturated 240cc
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
Re: OBDII b20b in a del sol?
I would suggest you get the injectors that will plug into your harness. It does not matter if they are peak and hold or saturated. For the peak and hold you will need to add a resistor box. Mostly you will go with the saturated.
