stripping paint off plastics? aircraft stripper?
I want to repaint my hubcaps cause the paint is flakin off. What is the easiest way to remove the old paint? I was gonna use aircraft stripper but then i was afraid it would eat away at the plastic itself... ideas?
Thanks!
Thanks!
Ek Forever y0!
Re: stripping paint off plastics? aircraft stripper? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Use some steel wool and rough up the paint, then paint over it. </TD></TR></TABLE>
That's what I would do.
Paint em BRONZE!!
Paint em BRONZE!!
Re: (turbotime)
It will but use a very high grit. Wetsand 600 and up will do the trick. Reason being that if you use course grit youll eat away the plastic and itll look like **** and uneven (depending on the color you use).
Ek Forever y0!
Re: stripping paint off plastics? aircraft stripper? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">All this for hub caps?</TD></TR></TABLE>
That;s why I said he should at least do some cool color. There's a guy in my hometown rocking gloss black hubcaps. Doesn't look too bad.
Imperious: Mod of Valor
Re: stripping paint off plastics? aircraft stripper? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
That;s why I said he should at least do some cool color. There's a guy in my hometown rocking gloss black hubcaps. Doesn't look too bad.</TD></TR></TABLE>
Hmm.. I would rather just get wheels, that's just me though.
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">yeah these are for my beater painteing them gloss white with black honda symbol, better than nothing </TD></TR></TABLE>
Right on man, I was just curious; that's all. I wasn't trying to rag on your thread. I've always wanted to paint steelies, hehe.
Re: (turbotime)
i used some aircraft stripper on some of my old side moldings and it started to eat away at the plastic within about 5 minutes....so I would suggest using sand paper, sand it down with some 180, prime it, then sand it down with 320, then paint
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">will sandpaper work?</TD></TR></TABLE>
You'll end up scratchin your hubbies if you do that.
Give em a power wash before you paint em again.
Good luck man
Good luck man
Re: (blk_EK)
I be rockin da highgloss black steelies with the honda cap panted red and the h silver an i must say they be sexy from afar but dont get to close lol
Re: (Jhonny Ricer)
I would take some steel wool to them or some fine sandpaper. Since you are going to paint over them scratch marks from the sand paper won't show unless they are absolutely huge.
Re: (okdc2)
800 grit automotive sandpaper wet or dry by 3m works well just wet sand em down in a swirling motion and spray em thats what i used for my steelies
em Dot
13
06-14-2007 08:19 PM
