for you guys who has done rear brake conversions
soon i am about to do my rear brake swap. my worry is on the trailing are and compensator arm. my bolts are alittle rusty and i am afraid that if i start working on them that the head of the bolt will break, just like my rear shock/LCA bolt broke.
is this a common thing? any ideas that i should try to prevent this from happening?
has this ever happen to anybody out there? what was done to correct the problem?
Re: for you guys who has done rear brake conversions (philosofy1)
Yeah, treat the bolts with some serious amounts of penetrating oil for a decent amount of time, and then cross your fingers. Rust is gnarly. If you want to get them out and not have to deal with the nail-biting subject anymore, get some replacements, and once they're out, put the new ones in.
Re: for you guys who has done rear brake conversions (BlueIntegraBoy)
pb blaster like everyone says.....and i always use a burnzalot torch for about a minute if it gives me any trouble at all. heat and pb will loosen just about anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Never had a problem with my suspension. All bolts were easy to take off. Watch out for the toe arm bolt, the welded nut might break off.</TD></TR></TABLE>
this was my pit-fall
must be nice. my lower control arm bolts were siezed in the bushings, so i had to replace both. also the compensating arm bolts can be fun removing if they are siezed up. good luck.
penatrating oil a few times soak and drive soak and drive. I had problems with my rear toe adjuster bolts. The bolt came out of the nut but was siezed in the bushing. so I had to cut both sides of the bolt off and just replaced the toe link with the adjustable spc link both toe and camber nice parts
Charlie Moua
15
09-05-2014 01:51 PM
If my back rear LCA bolts are seized up does that mean i have to get new bushings and break the bolt
Soda Popinski
03-30-2004 05:18 PM
2001, arms, blaster, brake, bushings, civic, compensating, conversions, crx, honda, link, rear, replacement, rusted, toe
