Engine check light?
Re: Engine check light? (Serdar)
You didnt hook up your knock sensor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Apparently you missed the cel code sticky:
https://honda-tech.com/zerothread/1901557
By the way, it's the code for a knock sensor.</TD></TR></TABLE>
EDIT: Beat me too it. You have an OBD2 motor in your OBD1 car. Theres no wiring for the sensor so you have to run the wire through the firewall and to the ecu. Very simple. If you can swap a motor, you can run a single wire.
Re: Engine check light? (93eg2james)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james »</TD></TR><TR><TD CLASS="quote">You didnt hook up your knock sensor...
EDIT: You have an OBD2 motor in your OBD1 car. Theres no wiring for the sensor so you have to run the wire through the firewall and to the ecu. Very simple. If you can swap a motor, you can run a single wire.</TD></TR></TABLE>
-Ran knock sensor, car has been on the road since december 06. This is the first engine check light mishap and hopefully last one.
Yesterday it came on and now tonight.
R_Machine
09-10-2005 11:59 PM
