Secondary o2 sensor??
How come my 97 civic dx engine harness have both primary and secondary o2 sensor and my 97 civic ex engine harness don't have the secondary o2 sensor, but the primary one? Plus my 99 civic ex engine harness don't even have the secondary o2 sensor only the primary one. Does the ex engine harness come with secondary o2 sensor or not?
Re: Secondary o2 sensor?? (Padawan)
I did a swap. D16y8 to a 97 civic hb. It's throwing code for the secondar o2 sensor. How would i solve this problem?
Re: Secondary o2 sensor?? (team 15)
How would I wire up the secondary o2 sensor if the engine harness doesn't have one. Can i wire it to the primary one?
the DX harness has the secondary O2 wired right into the harness. the EX harness , the secondary O2 sensor is not ran in the main engine harness. its in the dash harness. so you need to run new wires from the ecu to the secondary O2 sensor. find the proper pin locations , pin the wires , and run them to the sensor.
Darth ModerVader
Re: Secondary o2 sensor?? (blackKready)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">so you need to run new wires from the ecu to the secondary O2 sensor. find the proper pin locations , pin the wires , and run them to the sensor.</TD></TR></TABLE>
Just what I was in the process of writing.
^bingo
your pinout for an obd2a ecu is here:
http://technet.ff-squad.com/wiring.obd2a.htm
Snag some ecu pins at a junk yard and insert them into the connector clips
Location: The Village Hidden in the Leaves: Seattle, WA
i gotta do this for my car too. sucks. has anyone tried wiring up the secondary o2 sensor to the ecu, but leaving the the o2 sensor just wrapped up in foil? someone told me this works, but im not too sure.
Re: (kidsafe yee)
I could be wrong but im pretty sure the secondary o2 has to read a flow so you can bung the o2 raising it mostly out of the exhaust flow so it doesnt read anything shitty in the exhaust that would normally trip a CEL, but it is still in the exhaust flow so it doesnt trip the CEL for having no flow. Someone back me up... a friend of mine did it on his E36 M3 and it worked but if foil works too thats probably cheaper lol
InTheZoneAC
12
05-25-2011 07:08 PM
