replacing crank sensor
i need to know where to find my crank sensor for my 97 civic ex. my check engine light is on and the shop said it was the crank sensor. they said it's easy to replace but i don't know where to find it. any tips on replacing it would be greatly appreicated.
Re: replacing crank sensor (j_torres707)
Crank Position or Crank Fluctuation sensor?
One is on the end of the crank, mounted to the oil pump housing, the other is inside the distributor.
Re: replacing crank sensor (Slurp56)
its a CKF im assuming , cause if it was a CKP , the car most likely wouldnt run. also , most of the time , the CKP wont give a CEL. the car just stops and wont run anymore , or runs like timing is way off.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 »</TD></TR><TR><TD CLASS="quote">Crank Position or Crank Fluctuation sensor?
One is on the end of the crank, mounted to the oil pump housing, the other is inside the distributor.</TD></TR></TABLE>
