radiator fan relay
Re: radiator fan relay (allmotorkilla03)
the relay is off the computer...cuz it reads temp first before the fan turns on or off...you can follow the line on the passenger side harness and it pulls through t he firewall into the computer...there are other ways to bypass like hooking up to other sensors...cooling...oil....but thats hard ish to do
Re: (allmotorkilla03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorkilla03 »</TD></TR><TR><TD CLASS="quote">now i get cold air when i turn on the heat i dunt kno what to do</TD></TR></TABLE>
I thought the heat came from a hose connected to the block?
Ok, pop your hood and go to the back left side of your car by the battery (if you are facing it). The Cooling Fan Fuse (15a) is on the back row, second from the right... so thats 3 in from the left. Now, the Cooling Fan Relay is the 1st relay on the column if you are going from top to bottom (there are only 3). I hope this helps
