HELP! parking lights dont work but signal does.93 ex
* B A N N E D *
ok so today i installed my jdm sidemarkers. i spliced the red wire and black wire on the corner sockets and connected on my sidemarkers. well for some reason at first i connected them properly but the sidemarkers only stayed on but wouldnt blink. then i went to the store and came back and my parking lights wouldnt work but they would still blink when i signal or use the hazard lights. could it be a fuse popped because i didnt tape the connection of the wires? i used plain old speaker wires. since then i disconnected the sidemarkers and just connected the corners like how they were from the factory. they still dont work but there is power going to the corner lights because it works when i signal. if it a fuse or somethhing else i can check? btw car is a 93 civic ex. check the fuse box and under the steering column but not sure which fuse to replace. thanks any help will help. if you had this problem before help me out. thanks guys.. please dont say search because i did and i cant find one that matches my problem..
* B A N N E D *
btw if it is a fuse which one? under the hood or sterring column? thanks btw just went outside to check my lights.... the parking lights and the tail lights dont light up. they only work when i push the hazard lights,brake,signal. any help on which fuse to change or what to check will be very greatful so i dont waste money on unessesary parts...
Modified by cambosoup at 9:20 PM 3/29/2007
Re: (cambosoup)
sounds like you blew the fuse for tail/ instrument lights. Its in the under dash fuse box. Not sure what number it is just pull each one and check it. Oh do yourself a favor get someone that knows how to do auto wiring correctly and not your buddy that uses electrical tape to cover up the splice.
* B A N N E D *
yeah i stopped trying to do connections. im gonna bring it to the shop to get it hooked up but as for njow im just gonna have them on for show.. thanks a bunch going to get the fuse right now!! awesome info bro!!
Re: (cambosoup)
prolly just a fuse bro. There should be a graph of your fuse locations in your Honda Manual.
Otherwise its just a bad connection from your E-light switch to your bulb itself.
* B A N N E D *
thanks guys i checked the fuse.. thanks for telling the exact one.. im going to buy new ones. mods close this thread. thanks instructer74 and blk_ek for helping and not telling me to search..
Dogsticks
09-04-2012 10:29 PM
