95 civic d16z6 cam gear install
does anyone know how to install an aem adj cam gear in a sohc?
a step by step with pics would be greatly appreciated
thanks,
Travis.
thanks,
Travis.
kewl..i also need help as well..just got a aem cam gear for my d16z6..but also another questions..i heard that these are just good for looks..does it actually help ur car at all?
Re: 95 civic d16z6 cam gear install (95hatchcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchcivic »</TD></TR><TR><TD CLASS="quote">does anyone know how to install an aem adj cam gear in a sohc?
thanks,
Travis.</TD></TR></TABLE>
I would honestly help you, but i dont have pics for you, and i dont really remember step by step....kinda just figure it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki »</TD></TR><TR><TD CLASS="quote">kewl..i also need help as well..just got a aem cam gear for my d16z6..but also another questions..i heard that these are just good for looks..does it actually help ur car at all?</TD></TR></TABLE>
It's good for looks, but it is also only really used for tuning purposes. Specifically to adjust cam timing when you have aftermarket cams/cam and looking for maximum output. Other than that, not really.
thanks,
thanks,
If you can get the first issue of Project Car magazine or look at their website they did a write up on installing the aem camgear on a z6. Pretty much all you're gonna do is remove the valve cover, remove the upper timimng belt cover, loosen the timing belt tensioner, unscrew the bolt for the gear, place the new gear on, tighten the bolt, and adjust the timing belt. You'll want to make sure the gear is set at zero degrees and place all the covers back on.
thanks,
Re: (95hatchcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatchcivic »</TD></TR><TR><TD CLASS="quote">still in need of a pic walk thru or an exact step by step, Do i have to set the motor to tdc? do i have to re-set my timing at all?</TD></TR></TABLE>
Bro honestly....
All this can be found by searching...this is Honda-Tech, the largest forum for Honda enthusiasts. This top has been easily covered a bajillion times...yes you have to set the motor to TDC, and you can re-adjust your CAM TIMING by advancing or retarding a degree, or a degree and a half....remember, ignition and cam timing are two different things.
Bro honestly....
Re: (illusionz xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illusionz xx »</TD></TR><TR><TD CLASS="quote">there is really no point of putting in the cam gear unless you have aftermarket cams, unless you are going for looks.</TD></TR></TABLE>
x2...and if you plan on cutting your valve cover. Even people with built motors only put these on when it comes time to tune. Waste of money if you are throwing this on a stock car IMO
