Keyless Entry Programming?
Old Mar 28, 2007 | 01:13 PM
RA217252's Avatar
Default Keyless Entry Programming?
99 Civic SI
I have the instructions on how to program the keyless remote. However it isnt working. There is a ticking noise inside the car. The noise doesnt stop, it keeps going even when the key is out of the car. Could that be the problem?
Old Mar 28, 2007 | 01:33 PM
Shaun_'s Avatar
Run down to the dealer real quick and they will program it for free.
Old Mar 28, 2007 | 01:35 PM
RA217252's Avatar
Default Re: (Shaun_)
That is an option Any other advice, I'd like to try and figure this out myself?
Old Mar 28, 2007 | 01:47 PM
cxSHOE's Avatar
Default Re: Keyless Entry Programming? (sheehan024)
remove your door panels you may just need more grease, the rod could be stuck.
Old Mar 28, 2007 | 02:09 PM
Chim Chim's Avatar
If you don't have the stock head unit, you won't be able to program anything. The reciever for the keyless entry is built into the stock headunit.
Old Mar 28, 2007 | 03:00 PM
rust_free_civic's Avatar
I think the doors need to be closed when you program it
Old Mar 28, 2007 | 08:18 PM
RA217252's Avatar
Default Re: Keyless Entry Programming? (rust_free_civic)
The doors, hoods, trunk were all closed. However the window was open. That may be the problem. As for the headunit, it's stock. Thanks for everyone responding. Anyone else with some advice. I'll be trying it again tm. <3 honda-tech.com
Old Mar 28, 2007 | 11:56 PM
NOFX's Avatar
H-T White Ops
Default Re: Keyless Entry Programming? (Chim Chim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have the stock head unit, you won't be able to program anything. The reciever for the keyless entry is built into the stock headunit.</TD></TR></TABLE>
That's only for the '96-'98 models. The '99-'00 models are not on the factory head unit.
My factory keyless was always difficult to program too. It usually took some time to get it right, and I couldn't program more than one remote even if I followed the directions perfectly.
tphilpot711
Honda CR-V & Element
Oct 11, 2017 06:39 PM
5G_Vtec
Mar 6, 2009 09:28 AM
94jdmeg
Honda Civic (2006 - 2015)
Dec 18, 2007 06:34 PM
joeyttw
Nov 4, 2006 07:06 AM
Setsuna F Seiei
May 3, 2006 08:55 AM
