USDM ITR Header in a 2000 civic si?
Old 03-29-2007, 02:50 PM
killaj12's Avatar
Default USDM ITR Header in a 2000 civic si?
sup guys ..
right now i have a dc header, high flow cat and greddy evo2
i want to replace the header with a usdm itr unit b/c the dc is dented and i think i developed a leak on it
would an usdm ITR header fit in a 2000 civic si?
and would it bolt straight up with no modifications?
help me out ht, thanks
Old 03-29-2007, 02:53 PM
Sloshy's Avatar
i thinks it should be a little longer at the bottom so youy might have to modified your exhaust pipe a little
Old 03-29-2007, 02:54 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: (hatch-E-vanish)
yes, it will bolt up but the end of the header will be a few inches closer to the ground than the OEM one.
Just get an aftermarket one so you don't have to worry about it rubbing.
Old 03-29-2007, 02:56 PM
killaj12's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">yes, it will bolt up but the end of the header will be a few inches closer to the ground than the OEM one.
Just get an aftermarket one so you don't have to worry about it rubbing.</TD></TR></TABLE>
really? damn.
i'm pretty low right now, so it wouldn't be a good idea?
Old 03-29-2007, 03:01 PM
Ek Forever y0!
Default Re: (killaj12)
Yeah if you have anything more than a mild drop it's going to scrub on all kinds of ****.
Old 03-29-2007, 03:21 PM
JDM-EJ698's Avatar
No it will be fine.I had it on mine before I swaped.I never scrapped and my tires are tucking
Old 03-29-2007, 04:42 PM
killaj12's Avatar
on a b16 in an, i assume, ej6 coupe?
i don't know who to listen to ..
can anyone confirm?
Old 03-29-2007, 05:22 PM
Johnny Ricer's Avatar
depends on how you drive and what your roads are like id say
if you have bumpy uneven roads, steep hills, and pot holes everywhere its gunna scrape id say but if your roads are even, with subtle hills, and your roads are well maintained id say you can prob pull it off with minimum scraping
Old 03-29-2007, 05:39 PM
Darth ModerVader
Padawan's Avatar
Default Re: USDM ITR Header in a 2000 civic si? (killaj12)
The manifold really won't hang very low. The main issue is that the flange at the collector is positioned at a different angle on the ITR manifold than it is on the Si manifold. Therefore, you either need to use an ITR cat, or modify your Si's cat in order to install the ITR manifold.
Old 03-29-2007, 05:42 PM
Timmay's Avatar
Default Re: USDM ITR Header in a 2000 civic si? (Padawan)
i had a stock usdm ITR header with stock civic cat on my 95 b16a coupe.. didnt have to modify anything and it wasnt near as low as my DC
Old 03-29-2007, 05:47 PM
Darth ModerVader
Padawan's Avatar
Default Re: USDM ITR Header in a 2000 civic si? (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">i had a stock usdm ITR header with stock civic cat on my 95 b16a coupe.. didnt have to modify anything and it wasnt near as low as my DC</TD></TR></TABLE>
Well, I can say with certainty that the stock ITR manifold <u>won't</u> bolt to a '99 Civic Si cat. I had to use the ITR cat in order for it to line up properly.
Old 03-29-2007, 07:08 PM
killaj12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The manifold really won't hang very low. The main issue is that the flange at the collector is positioned at a different angle on the ITR manifold than it is on the Si manifold. Therefore, you either need to use an ITR cat, or modify your Si's cat in order to install the ITR manifold.</TD></TR></TABLE>
how would i go about modifying my cat? would i have to go to a muffler shop?
Old 03-30-2007, 04:14 AM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaj12 &raquo;</TD></TR><TR><TD CLASS="quote">how would i go about modifying my cat? would i have to go to a muffler shop?</TD></TR></TABLE>
Yes, unless you know how to weld and have the equipment.
Old 03-30-2007, 06:35 AM
JDM_teh_WIN!!'s Avatar
I have a JDM ITR header on a JDM B16 in a 96 civic coupe. I use a skid plate. Fastline has a good one and its cheap. My car is slammed and it does occasionally come in contact with the ground.
This is for a JDm 4-1 header, so I dont know if it will bolt up to a USDM header. I would suggest the JDM header. You can find them for $350 or so. Also if you get a JDM header you can use the 2.5in test pipe.
http://www.fastlineperformance.com/skidplate.htm
As far as the cat and header bolting up. You will need to modify the flange that connects to the header. You can always run a omni power test pipe as well.
Old 03-30-2007, 06:57 AM
93CX's Avatar
Default Re: USDM ITR Header in a 2000 civic si? (JDM_teh_WIN!!)
slammage + oversized headers + skidplate = no worries
B20EF
09-17-2006 02:14 PM
StayTuned12
05-10-2005 01:03 PM
integrasi
07-12-2004 09:51 AM
toyoter91
05-10-2003 02:00 PM
YellowSpeed
03-05-2002 01:55 PM
Quick Reply: USDM ITR Header in a 2000 civic si?
