Faded rough window trim?
Old 08-10-2011, 08:11 AM
Lightsped's Avatar
Default Faded rough window trim?
The door trim at the bottom of the windows is all faded and rough. It is almost turning a chrome color.
What can I do to fix this trim? I checked online and was unable to locate a replacement trim.
Old 08-10-2011, 08:46 AM
PHANTOM MENACE
24TEN's Avatar
Default Re: Faded rough window trim?
In the FAQ there's a link to common online stores for OEM replacements. If OEM is not what your looking for, you can always take them off and paint them...or put a strip of black electrical tape if you just want a quick "cosmetic" fix.
Old 08-10-2011, 10:55 AM
Lightsped's Avatar
I may just pull them off and paint them. Looks pretty easy to remove once the B-pillar trim is off.
Old 08-11-2011, 07:47 PM
thatej6guy's Avatar
here is a link for what your looking for......http://www.hondaautomotiveparts.com/...tcgry5=MOLDING
Old 08-11-2011, 07:54 PM
Former User's Avatar
Anyone know of a good DIY for painting the window trim? The two trim pieces each cost $56 for my 00 Civic EX coupe.
Old 08-11-2011, 08:54 PM
untitled001's Avatar
It should be like painting any other part. pull them off, scuff them, then primer, then paint.
Old 08-11-2011, 09:00 PM
The original seems to be a dull black color. What's an appropriate type of paint? Any special type of primer for the scuffed metal? Spray paint or brush? I obviously don't know much about car painting.
Old 08-12-2011, 12:00 AM
PHANTOM MENACE
24TEN's Avatar
My friend got a fresh set a few months ago and it appeared to be more of a rubberized coating than a paint. It sort of makes sense as the ones on my car are brittle and peeling off in little chunks. If it doesn't matter too much to you just scuff them as "untitled001" stated and pick your color of choice. If you want to take it a step further you can try to find a local powdercoater or rhinolining place and see what they have that's comparable to the original stuff (last time I went to my local powdercoater they did offer some sort of rubberized spray on coating).
Old 08-12-2011, 03:36 AM
Ek Forever y0!
Libertariat's Avatar
To be honest I don't see the harm in picking a quality spray paint that is the approximate color match. It will certainly be better than the faded chrome look. I've painted my wipers with just some black paint and I don't think it contrasts with the black trim pieces.
Old 08-12-2011, 04:57 AM
NACvicSi's Avatar
Wonder what it would look like painted with the undercoating/bedliner type material? It's a dull plastic type finish also.
LadyCamouflage
03-11-2013 04:33 AM
Vizio2012
10
03-16-2012 07:01 AM
MDM
01-31-2009 12:56 PM
AMG
60
06-11-2004 01:59 PM
zzzkenji
05-20-2003 07:28 AM
Quick Reply: Faded rough window trim?
