1999 civic si engine belt(s) replacement DIY?
Old 08-08-2011, 09:58 AM
BNSTKSI's Avatar
Default 1999 civic si engine belt(s) replacement DIY?
Im looking for a DIY thread for replacing my A/C, Alternator and Power Steering belts. Just by looking at first glance, im sure its going to be difficult but do-able. I just wanted something go help me go by incase I was to come across a snag along the way. I tried the search and didn't really see much on there for this topic. If anyone knows or a link or anything along those lines, please let me in on it.
Thanks in advance...
Old 08-08-2011, 10:08 AM
Linked's Avatar
Default Re: 1999 civic si engine belt(s) replacement DIY?
there really isnt any tough processes to go through, just key points you will have to take into consideration
-the PS belt comes off first, and the pump pulley itself tensions the belt, the pump will lower on a threaded stud to loosen the belt
-the AC belt comes off second, and is tightened by a idler pulley, loosen and take that belt off
-the alternator belt comes off last, and is similar to the PS belt, the alternator pulley tensions the belt and will have to loosen the belt by moving the alternator
Old 08-08-2011, 10:09 AM
Mike Jones
SlowPokeEg's Avatar
If you're a little in the dark in simple maintenance, a Haynes (sp) manual from Autozone can be a pretty good help
Old 08-08-2011, 11:08 AM
Technical Hero
HondaPartsHero's Avatar
http://www.clubcivic.com/board/showthread.php?t=143137
its generally for a civic but it should be similar enough
CALC!_JUST_du_IT!
06-10-2008 12:55 PM
dotay
12-30-2006 01:35 PM
Import_Dumbass
10
05-21-2006 03:59 PM
T--Rex
07-14-2004 04:44 PM
keithv
08-07-2002 04:40 AM
Quick Reply: 1999 civic si engine belt(s) replacement DIY?
