Alternator Wiring
Mike Jones
Alternator Wiring
The wire on top that is held on by a nut and has the tophat....does this wire go straight back to the fuse box? In other words, can I just unhook it and run a new (longer) wire to the fuse box and be able to put my fusebox where I please?
Do you guys ground off this pivot bracket? Not really sure where exactly to run my alternator ground from.
Thanks!
Thanks!
Re: Alternator Wiring
Mike Jones
As you can see I got a Chasebays ground kit for the "bling" factor. There is 3 grounds included. Valve cover, trans, and I assume Alt. Also, you can see my oil pressure sending unit is on the sandwich adapter. I was also going to run that ground to the alt. bracket.
Correct me if I'm wrong on anything, and THANKS for the response!
