B18C5 What fitting is this?? Help!!!
Sup fellas, getting ready to drop the motor in and realized I don't have this fitting installed in the block, going by the oil cooler coolant lines, it appears to just tap into the coolant jacket on the block and my oil cooler line connects to it? Any one know the name of the fitting or the size or where I can get it? I looked at diagrams on Majestic and they don't show the fitting...
Re: B18C5 What fitting is this?? Help!!!
the drain on my y7 is above the oil filter. that empty nipple on the intake is proably where your cooler line goes.
Ok, I found a diagram from Delray Acura and I think what I need is item #1 in this parts diagram... although they list it as a oil cooler joint?
It appears to me to just be a screw in nipple where the coolant return connects to from the oil cooler.
you want # 17 and 25 http://www.acuraoemparts.com/delray/...All&vinsrch=no
Nope thats on the front of the block, this is the back just above and to the right of the oil cooler. I figured it out after seeing another pic on H-T of another members C5 motor. Its in fact a screw in fitting with a barbed end for the oil cooler line to attach to.
Thanks,
Thanks,
seen4ever
05-15-2006 09:56 AM
skunk2finatic
12-16-2004 02:46 PM
