93 civic ashtray light????
Re: 93 civic ashtray light????
I also just found this out this weekend on a pick a part run to replace that entire lower center ash tray piece lol mine doesn't work either though so no idea if its blown/ doesn't work/ not wired properly
I dont know where the heck you'd find that bulb at though.....it looks just like the ones behind the faceplate of the climate control cluster though so maybe find those from honda.
i took it out and the bulb is blown...by the way when my headlights are off my clock brightness is strong ounce i switch it to headlights my clock dimms is it normal???? if not what it is?
you fix the voltage drop by replacing most likely the Alternator if it only does it while running if just off the battery its normal because youre illuminating the lights with the 12V source which is causing a voltage draw
Uhh, it is completely normal for the dash lights to dim when the headlights are on... they designed it that way. There is even a special dimmer circuit (and no, it is not the dashlight brightness controller dial, that's completely different) . The ashtray light turns on when you switch on the dash lights at the turning signal lever. The replacement bulb is #74 at any autoparts store. It is 14W.
The ones for the ashtray light and climate control panel are 74. I think some of the bulbs in the cluster are slightly larger. The shift position bulbs in the cluster on AT Civics are different, they are longer with really long wires and a rubber base. Those you might have to get from the dealership. If you're looking to wire up LED lights, it probably wouldn't be too hard to figure out a way to make them work.
ed2
06-08-2010 11:09 PM
flatblack-h22
12-04-2006 01:39 PM
pinoyboy204
12-26-2002 11:54 PM
