Threads for cam cap all stripped, dont know what to do
Old 08-12-2011, 06:49 AM
Swaggylicious
$amGD3's Avatar
Default Threads for cam cap all stripped, dont know what to do
The threads on my lower passenger side camshaft cap are done, which means I can't tighten my valve cover which means a constant oil leak. Honda doesnt sell this part, where can I possibly get this? Does any other vtec head share the same part??
It is the cam cap closest to the vtec solenoid for a B16A2 head.
The part is circled in the diagram below
Old 08-12-2011, 07:07 AM
20% cooler
thenext's Avatar
Default Re: Threads for cam cap all stripped, dont know what to do
Tap'n'die and Helicoil?
Old 08-12-2011, 08:31 AM
#1 Super Guy
94eg!'s Avatar
Helicoil or new cylinder head.
/thread
Old 08-12-2011, 09:07 AM
Dontoh's Avatar
go to a junkyard? or find another junk head and take it off that one.. make sure its the same head, i think different b series heads use different cam caps
Old 08-12-2011, 09:09 AM
turbodcxbro's Avatar
Outer Bolts are M6 x 1.0. Heli-coil kit would fix it easily!
$42 and your done!
http://www.mcmaster.com/#metric-fine...icoils/=dl7o4e
Old 08-12-2011, 10:25 AM
Seagull Management
94EG8's Avatar
Even if you take one off another identical head they still aren't the same, when the head is cast the holes aren't there, the cam caps are bolted on and then the head is line bored, if you mix and match cam caps you'll have an oval hole and you will have abnormal wear unless you get it line bored. Try to fix what you've got with a helicoil or threaded insert.
Old 08-12-2011, 10:28 AM
creationz's Avatar
All I did was replace the cap. I had 3 caps stripped on my ZC found a junk head pulled it all out and replaced it with new ones. Head was 20bucks...
Old 08-12-2011, 10:53 AM
Dontoh's Avatar
could quite possibly explain a few things..
Old 08-12-2011, 11:04 AM
strategy400's Avatar
Install helicoils taking care not to get metal shavings in your engine (plug and cover everything with rags. Make sure you drill/tap square and centered. Some type of jig may be advisable. You may have to drill deeper than the original hole. Make sure you have clearance for that.
In the future use an appropriate torque wrench (inch lb.) and tighten to spec. Aluminium is soft metal, cam cap bolts are hard metal. The different rates of heat expansion will also fatigue the aluminium threads.
Use the original cam caps.
Old 04-16-2018, 05:47 AM
c-Rexbuilder's Avatar
Post Re: Threads for cam cap all stripped, dont know what to do
hey, quick question looking at the diagram you posted i am curious to know what number 28 is and number 2 is on your picture, building my 16ba2 and was told this is not on mine.
Old 04-16-2018, 06:40 AM
Loves Tossing Salad
09chaplak's Avatar
https://www.hondapartsnow.com/parts-...dohc-vtec.html
Old 04-16-2018, 07:54 AM
Fish Twig
tony_2018's Avatar
I have heard this might not be true, its debatable. I'm unable to argue this point to your advantage because not many have come forward with having to bore out a new one.
dwerpk
03-03-2007 10:35 AM
MAPU
06-09-2006 02:46 AM
MAPU
06-03-2006 07:11 AM
ildknyli
10-10-2004 10:21 AM
96b18c
01-04-2004 05:02 PM
Quick Reply: Threads for cam cap all stripped, dont know what to do
