92 hatch b18 swap keeps blowing the main relay & CEL on but no codes retrieved
My check engine light is on but when i try the bypass trick and jump the wires it doesnt read out any codes???
i have a 92 hatch b18 swap and for some reason my main relay keeps blowing out on me. I've checked the asg fuse I checked all the power coming in and out of the main plug which checks out fine..I checked the power going to the fuel pump which is fine..I,ve swapped ecus, fuel pump, ignition, main relays. If I put a new relay in the car will crank but only will last about two minutes before dieing and not being able to crank back up... ANy help would be greatly apprciated
Re: keeps blowing main fuse?
well sorry i stated clearly in the post but not the subject its the main relay that keeps crapping out on me
hears what it does if i put a brand new relay it will give me the main relay gives its first click when key is turned to on position then second click for fuel pump to prime then third when cel goes out car cranks and runs fine for about two minutes then dies. Then when I try to restart it the relay clicks twice really fast fuel pump makes a click noise doesn't prime and cel will stay on. Now when the cel stays on I try to do the cel diagnostics but when I jump the two wires out by the ecu nothing happens
Re: 92 honda civic b18b swap - check engine light on but no codes retrieved
no it doesn't i also have the post about the main relay problem
Re: 92 hatch b18 swap keeps blowing the main relay & CEL on but no codes retrieved
yeah i checked the relays and they actually blow or short out ive tried them in my 95 civic and they don't work and the new ones i did buy worked in the 95 civic before putting them in my 92 and frying them
What's odd is that fuse 31 or 24 or 18 does not blow before the main relay fries. What amp rating fuses are installed in the fuse 31, 24, and 18 slots?
cant remember off the top of my head other than they are the correct fuses
ok i checked and redid all the grounds. I swapped out the fuel pump and swapped out the main harness to the ignition switch. I've tried numerous main relays. I put a different connector going to the fuel pump. I noticed I don't get any power when the key is in the number two position the clock and radio don't come on. I checked all the power going to the main relay harness and everything checks out. I have no blown fuses anywhere.I swapped out ecus. I'm totally stumped on this one can anybody help out???
